joker_fly
- Mar 5, 2017
- 7
- 0
- 2001
- Magnum 5.2
New questions
Wondering about cam and heads
If I use the stock heads (if not cracked)
Vs engine quest heads what will I lose hp wise
New cam in both theoretical applications
As I undersand I can run more lift with the engine quest heads but how much net gain will I recive over stock heads
Will eventually boost it to around 10-14psi but this is much later but if I'll get more out of the Engine quest heads I'll rather do that now when engine is out on stand
So what do you guys say
Stock non cracked heads vs engine quest heads looking for around 400hp non boosted
Also stock intake and a ported throttle body
Or is a new intake a must ? If boosting
