Camshaft specs
Discussion in 'Engine & Performance' started by Johnmopar1954, Dec 3, 2017.
Sponsored By: Moe's Performance
  1. Johnmopar1954
    Johnmopar1954 Junior Member
    Dec 3, 2017
    Ram Year:
    1999
    Engine:
    8.0 liter V-10
    Hi. New member here. Does anyone have camshaft specs for 1999 Dodge Ram 2500 V-10? I'm building my new engine for a twin turbo setup so I need to know lift, duration, etc. to see if I can have my cam ground for turbo specs.
  2. chrisp2493
    chrisp2493 Always Modding
    24
    2,379
    1,257
    Oct 30, 2016
    Warren, OH
    Ram Year:
    2003
    Engine:
    392 Hemi
    That sounds like an awesome build! Any pics?
  3. dudeman2009
    dudeman2009 Senior Member
    22
    1,532
    178
    Feb 9, 2016
    Lansing, Michigan
    Ram Year:
    2001 1500 Sport with enough electrical modifications to make my brain hurt
    Engine:
    Magnum 360
    Exhaust Closes (deg ATC) 25
    Exhaust opens (deg BBC) 60
    Exhaust duration (deg) 265
    Intake Closes (deg ABC) 61
    Intake opens (deg BTC) 6
    Intake duration (deg) 246
    Valve Overlap (deg) 31
    Compression Ratio 8.4
  4. dapepper9
    dapepper9 Senior Member
    22
    4,966
    1,887
    Feb 7, 2013
    Iowa/Nebraska Border
    Ram Year:
    2001
    Engine:
    5.9L V8
    I would honestly recommend just degreeing it so you know for sure
  5. jlbayes
    jlbayes Senior Member
    191
    14
    Aug 3, 2017
    Ram Year:
    2001 & 1997
    Engine:
    5.9l cummins
    Which would be after him getting his reground. Likely why he was asking.
    Op, wouldn't make more sense to buy a viper grind or an srt10 truck grind? Instead of regrinding your and removing the surface hardness?
  6. dapepper9
    22
    4,966
    1,887
    Feb 7, 2013
    Ram Year:
    2001
    Engine:
    5.9L V8
    How do you figure ? Gotta tear it down to pull the factory cam in the first place, very little work to pull the heads and set the equipment up and go from there. Then you have a for sure answer on what exactly you have and can move to something else from there. Rather than guessing with an internet spec sheet that is a crap shoot as to tyke accuracy
  7. jlbayes
    191
    14
    Aug 3, 2017
    Ram Year:
    2001 & 1997
    Engine:
    5.9l cummins
    My apologies. I did not see what you were getting at. Yes absolutely he could plot the lift points etc to get the idea of what he really has.
  8. dapepper9
    22
    4,966
    1,887
    Feb 7, 2013
    Ram Year:
    2001
    Engine:
    5.9L V8
    No worries. If it were one of the v8s i could post up specs and everything. The issue i see here is the v10s are pretty highly undocumented in these fields. The v8s are pretty widely documented themselves and there's a lot of bad info out there on them ranging from factory valve sizes and head differences, cam specs, and anything in between. I just think it's better to know for sure than to trust spotty documentation lol
  9. jlbayes
    191
    14
    Aug 3, 2017
    Ram Year:
    2001 & 1997
    Engine:
    5.9l cummins
    Ohhhhhh for sure. Cams are black magic in the diesel world still as well. Is about a joke.
Share This Page
