Can i use 20" without lifting?
RPAnderson2017
I have a 2016 Ram 1500. Right now it has 17" wheels.
Can I use 20" wheels without having to lift the truck?
JPT
NY
2015 Big Horn
Yes. It is the tire size that goes on that wheel will be the potential issue.
Maven05
You will be just fine. No lifting. Tires won't scratch.
Maven05
These are stock 20"
SYKRAMMAN
Banned
Jersey shore
06 Mega
My tuck came with 17"s and I put 275/75/20 with no problems but you have to get you're pcm flashed for the calibration of the bigger size tire. Stealership will cost a lot of $, local auto shop will be a lot less $
Gary2
S Jersey
I don't know how much it effects any of this but Most trucks with 20's have raised ride height option on the build sheet also
Mbrigh3
IG: Stormtrooper_5.7
MD
:signs1:yes! name calling, this could get interesting
smiley
Minot, ND
2014 Ram 2500 Crew
6.7L Cummins
Name calling is done. Clean up and be nice. Shouldn’t have to say that to adults. Enjoy the forum.
Ratket
Arizona-
Rpa - what 20” wheels do you want to use? Are they stock? If not stock do you have the specs on them?
I thought I already asked this question but I may have took a stab at someone in the same post so it may have got deleted.
