Can it be done?
Discussion in 'Lowered' started by racetrackpadre, Feb 27, 2014.
  1. racetrackpadre
    racetrackpadre Junior Member
    Feb 27, 2014
    Ram Year:
    2001
    Engine:
    318
    Can a 2001 Ram1500, 2wheel drive be lowered? If so, how (short of using a thorch)?
  2. dodge dude94
    dodge dude94 Senior Member
    23
    27,475
    6,271
    Sep 5, 2013
    East Texas
    Ram Year:
    1998 Ram 1500
    Engine:
    5.9 Magnum
    Shorter springs and shocks, and possibly lower control arms for the front and longer shackles for the rear plus maybe removing the overload spring from the leaf spring packs.
  3. WhiteExpress
    WhiteExpress Senior Member
    17,826
    3,102
    Sep 8, 2011
    Carlsbad, NM
    Ram Year:
    Engine:
    3.5 EcoBoost
    There are many aftermarket options available to lower this truck.
    Depends largely on the desired about of drop.
    Lower Control Arms are a great way to get low without a largely diminished ride quality.
    There is a lot of 'free' drop to be had be reworking the rear hangers and removing the over load springs. Or, if you're after more drop, you can do an axle over swap too.
  4. jmccullough
    jmccullough Junior Member
    28
    Mar 30, 2014
    odessa tx
    Ram Year:
    2001
    Engine:
    5.2
    mine has a axle flip in the back with a mini c notch from western chassis and lower control arms up front from djm suspension which came out to about a 4/6 drop
  5. rammanriley20
    rammanriley20 Senior Member
    1,502
    755
    Nov 4, 2013
    iowa
    Ram Year:
    1999 Ram 1500
    Engine:
    5.9 Mag
    cut coils, or remove them to run shocks
  6. tommyboi87
    tommyboi87 Senior Member
    861
    205
    May 28, 2014
    houma louisiana
    Ram Year:
    1999
    Engine:
    5.2 Magnum
    Jmc, I have a mine c notch but the rear ride quality is still crap. Do you know anywhere that has a prefabed full c notch for these trucks?
  7. jmccullough
    28
    Mar 30, 2014
    odessa tx
    Ram Year:
    2001
    Engine:
    5.2
    not that I know of. may have to try and get a universal kit. im getting mine from avsontheweb.com I believe there 110$ but ima get the notch and bridge kit for $220 here pretty soon
  8. tommyboi87
    861
    205
    May 28, 2014
    houma louisiana
    Ram Year:
    1999
    Engine:
    5.2 Magnum
    I'm gonna check them out. I need at least 8" or better to get back some ride quality.
  9. jmccullough
    28
    Mar 30, 2014
    odessa tx
    Ram Year:
    2001
    Engine:
    5.2
    Do u happen to have drop shocks in the back or the factory shocks?
Share This Page
