Can someone double check my wheel math?
Oliver Closehauf
Cincinnati
2005 Laramie
Cummins 5.9
If my stock wheels are 17x8 with +43mm offset and I'm looking at a wheel that is 18x9 with+12mm offset, I calculate that the inside edge of the rim would move outbound ~3/4 of an inch and the outside edge would move outbound ~1 3/4 of an inch as compared to stock.
Does that sound right?
Oliver Closehauf
Oliver Closehauf
Cincinnati
2005 Laramie
Cummins 5.9
Thanks! The site doesn't account for increased width, but if I add 1/2 inch to both sides, I do get agreement with my calculations.
MADDOG
Out Exploring Arizona
It may not be exactly 1/2 & 1/2 as you still need to account for the offset. A 0 offset puts the hub dead center in the wheel width measurement. If it is a positive or negative offset then some change to the numbers needs to me estimated. It's not a huge amount of movement but it's a good thing to know.
Oliver Closehauf
Oliver Closehauf
Cincinnati
2005 Laramie
Cummins 5.9
Right. I took that into account. The calculator on the site didn't include a width change. It was more for tires than wheels.
It was close enough to what I calculated on paper to call it confirmed.
One wheel site had a "visualizer" where you could pull up your truck, even choose a color and then select the rim to see what it would look like. There is no way its accurate. A 12mm offset would stick out much further than what they show. Too bad too since I really like the pattern.
Black1500Ram
Scottsdale, AZ
my math confirms yours ... inside edge of wheel will be 18.3mm (~3/4") further outward and outside of wheel will be 43.7mm further outward (~1.75") compared to stock.
check out customoffsets.com's gallery you can put in your wheel specs and they have pics of people with similar stances.
James
Oliver Closehauf
Oliver Closehauf
Cincinnati
2005 Laramie
Cummins 5.9
Yeah I was there. Thanks :)
Thats what was messing with me. Those pictures were much wider than stock, while the "visualizer" showed a very reasonable factory like stance.
1 and 3/4 inches is just too wide for me. I barley squeeze into my driveway as it is. Unless.....
Nope. I'd have to add flairs. I could probably handle 1 inch further out by going with a more vertical sidewall. The stock tires are kind of donut shaped.
