You ASSume Chrysler (FCA) was interested in selling the best engine and truck, rather than a good engine and truck for the most profit. Even $50 more in parts adds up to big money over a 100K vehicles.
Chrysler engineers, knowing the Hemi has a blow-by issue decided to pump the PCV waste into the intake. Lots of mfgrs do that, but the Hemi has a higher level of blow-by. No extra parts to install (i.e. catch can), just bump up the required octane to avoid detonation--
and that bill is on the owner.
Same with the stock intake. Its O.K., sucks an adequate amount of relatively cooler air through fender, but that articulated intake hose is turbulent. Better flow, better supply of O2 for combustion. Filter from factor is crap too. They also went with a narrow throttle body, adequate for a quiet stock truck with stock air box and stock exhaust.
The common element here is it is all about what is cheapest to Chrysler and easiest to assemble, with no extra parts required--and that saves FCA a lot of money. Its not like its safety issue like Ferd's Pinto, its just a corporate choice to
SUB-OPTIMIZE performance in favor of reduced build cost.
So if you're going to treat it like a lease vehicle with a low mileage turn-in limit, then stock is fine.
But your RAM has a Hemi and you might as well enjoy ALL it can deliver.
