Tach_tech
- Joined
- Jun 1, 2014
- Posts
- 3,307
- Reaction score
- 3,556
- Ram Year
- 2017
- Engine
- 5.7L HEMI
Finally back in town, trying to replace it how the hell do you get it off. It's rotated in such a way I can't see any tabs, but I can tell there isn't a red slide tab like I've seen a few others mention.
Sent from my Nexus 5X using Tapatalk
The oil pressure sensor usually doesn’t have the red lock tab on the connector. Some do, some don’t, but I haven’t seen one on a newer truck.
You have to depress the black tab on the connector the pull it off. If it’s dirty, squirt some penetrating fluid in it. As well sometimes it helps to push on the connector then press the tab before trying to pull it off.
