If you have any oil leaks in the vinicity of the covers,it's worth checking their bolt torque,although they don't seem to be as prone to loosening off as the intakes do,but it never hurts to check them to every once inawhile.
The valve covers call for 106 in-lbs ,just slightly under the intake bolts at 108 in-lbs / 9 ft-lb,at least that's what my book says,although this guy says 70 in-lbs. My book is on the cars,but i can't see them being any differant then the trucks,as they use the same valve cover to my knowledge. Hopefully some one who has access to the trucks tear down manual will post up what the trucks call for if it's differant then the cars 106 in-lbs
Shop for New Auto Parts at 1AAuto.com http://1aau.to/c/137/aq/gasketsThis video shows you how to install a new set of valve cover gaskets on your 2011-2018 R...
www.youtube.com
