Cleaning my bed liner
Villalobos
USA
5.7l hemi
Had the truck about a month, previous owner took very good care of it. Bed liner, however, was neglected. I grabbed some stuff that I had lying around: Mother’s black streak remover, smells like a citrus cleaner. I use it on my camper so I know it’s a gentle cleaner. Sprayed it on and let soak then used a plastic bristle brushed and scrubbed it in, then rinsed with water and let dry. Then used the Mother’s VLR. I was going to use microfiber, but thought about the snags. Just sprayed it on thick and blotted it in with a compound pad. Worked great!437260AE-5BE6-4E56-97DF-9ABC37CF036B.jpeg E7F4DFC8-920E-40AF-809B-2CA092D82A14.jpeg 401B0A67-6BFD-40B7-9612-A70AAF8F9C4D.jpeg 437260AE-5BE6-4E56-97DF-9ABC37CF036B.jpeg E7F4DFC8-920E-40AF-809B-2CA092D82A14.jpeg 401B0A67-6BFD-40B7-9612-A70AAF8F9C4D.jpeg 437260AE-5BE6-4E56-97DF-9ABC37CF036B.jpeg E7F4DFC8-920E-40AF-809B-2CA092D82A14.jpeg 401B0A67-6BFD-40B7-9612-A70AAF8F9C4D.jpeg 437260AE-5BE6-4E56-97DF-9ABC37CF036B.jpeg E7F4DFC8-920E-40AF-809B-2CA092D82A14.jpeg 401B0A67-6BFD-40B7-9612-A70AAF8F9C4D.jpeg 437260AE-5BE6-4E56-97DF-9ABC37CF036B.jpeg E7F4DFC8-920E-40AF-809B-2CA092D82A14.jpeg 401B0A67-6BFD-40B7-9612-A70AAF8F9C4D.jpeg 437260AE-5BE6-4E56-97DF-9ABC37CF036B.jpeg
Villalobos
Villalobos
USA
5.7l hemi
:sorry:Not sure why posted 6 sets of pics
NOV87
PNW
Looks very clean! I need to do this to mine.
WY-Dave
Cheyenne, WY
6.7 CTD
Bucket of soap and a nylon broom is what I use and looks as good as new. But with the dirt roads and no tailgate seal, looks the same after a drive haha
WhiteExpress
Midland, TX
Man! That looks 100% better. Well done.
I scrub mine with Simple Green and a wheel brush once or twice a year.
It's got a bed cover, but it's got a hard life (it IS a work truck).
dale197338
US
2018 Ram 1500 4X4
I just removed mine completely.
Sent from my Moto Z (2) using Tapatalk
chris1126
RAMINA
pa
Had the truck about a month, previous owner took very good care of it. Bed liner, however, was neglected. I grabbed some stuff that I had lying around: Mother’s black streak remover, smells like a citrus cleaner. I use it on my camper so I know it’s a gentle cleaner. Sprayed it on and let soak then used a plastic bristle brushed and scrubbed it in, then rinsed with water and let dry. Then used the Mother’s VLR. I was going to use microfiber, but thought about the snags. Just sprayed it on thick and blotted it in with a compound pad. Worked great!View attachment 218833 View attachment 218834 View attachment 218835 View attachment 218833 View attachment 218834 View attachment 218835 View attachment 218833 View attachment 218834 View attachment 218835 View attachment 218833 View attachment 218834 View attachment 218835 View attachment 218833 View attachment 218834 View attachment 218835 View attachment 218833
is that a spray in liner?
Villalobos
Villalobos
USA
5.7l hemi
Yes, it’s on the window sticker under options, as spray-in bed liner.
Riverside California
2018 2wd
HEMI 5.7 Revolution 4.88s
You should re-spray it with some Raptor bedliner, you would only need maybe 2 bottles just to get that nice deep black and better looking texture again ... something to think about ...
I'm about to spray my truck with it, doing the bumpers, bed, fender flares, grille ... can't wait !
kidmandudebro
Connecticut
Me too, I just ripped mine out by myself with minimal marks underneath on my bed, I got lucky. But bulk head will need a little touch up paint wise. I used a little rubbing alcohol to clean it up for now.
So much better now, those plastic bedliners are terrible and can trap dirt and moisture for sure.
I went with a Gator EFX hard Tonneau cover and dry in there so far!
Villalobos
Villalobos
USA
5.7l hemi
You probably still would want to clean it before spraying more, no? Can you just rip out a spray in liner?
Administrator
Not if the bed was prepped properly before it was sprayed on. I've seen pics of OEM spray liners come off in large sections. Line-X offers a ReNew option for spraying over existing spray in liners.
TC
Central TX
Forever Black Bedliner Gel
This stuff is the bomb.
Villalobos
Villalobos
USA
5.7l hemi
The liner wasn’t faded, just dirty. Truck has a hard tonneau cover, guessing that protected from fading. More bed liner spray or dye wasn’t necessary. This was cheap as I already had stuff lying around and a bit of my time.. I got lucky with my truck, and loving it. Thanks for the suggestions, will keep in mind if I ever need to restore it, this was just a clean and protect.
