James Vellenga
- Sep 10, 2020
- 21
- 1
- Location
- London, Ontario
- 2008
- Hemi 5.7
I have been fixing various things on my 2005 Ram. After doing some front-end work, the rear u-joint which was probably going for a while started producing a lot of vibrations at highway speeds. I replace the u-joints, and the last thing I have left is a shudder or clunkiness when starting from a stopped position while turning. It doesn't happen when going straight or when turning while moving only from a stop or very near complete stop. My guess is it is the locking rear diff, although when I did the rear u-joint it was the first one I ever did, and I did struggle with it far more than the front one on the driveshaft. I am wondering about people's thoughts on possible causes.
My plan is to check the driveshaft to make sure the u-joints have no play and are moving freely as that will at least set my mind at ease about them. If the rear one which I did first is binding at all, I will deal with that. If everything looks and feels good. I will drain the diff and replace the fluid and friction modifier using the one from Mopar since when I did it when I purchase the truck two years back I didn't use the Mopar friction modified, and reading around today people say that may be an issue. I would like to figure it out before heading out camping in a few weeks.
