Fishstickz
- Jul 20, 2017
- 636
- 357
- Location
- Oklahoma
- '06, '16
- 3.7, 5.7 Hemi
So I’m planning on replacing my instrument cluster anyways, but thought I might as well see what yall think about this.
Ever since I bought this truck most of the warning lights didn’t work. Brake light, ABS light, check engine light, among others. From running AlfaOBD thru the truck, apparently the ABS light and check engine light should both be lit up (VIN mismatch bullcrap) but neither of them are. I was curious so I ran the gauge cluster test and also used AlfaOBD to connect to the cluster and went thru to turn on each warning light separately, these four never came on.
I believe the truck does make an extra chime on startup due to the ABS fault, but the lights never come on. Has anyone else ever seen this?
