Sherman Bird
- Jun 28, 2019
- 1,553
- 2,357
- Location
- Houston, Texas
- 1998
- 5.2
It's time for a good scanner to map Fuel control. However, there are 3 things which must be looked at.I have a 2012 Ram 1500 with an interesting problem, well for me anyway.
It starts normally and well cold or hot. But with cold start, and starting to drive, it has almost no power and there feels to be a slight miss. If it was a carburetted vehicle, I would think that the power valve was stuck closed. Once it warms up it appears to run fine. The other interesting part is that the fuel economy dropped from 21 -22 MPG on the highway down to 14 MPG highway.
The spark plugs were recently replaced with no improvement. Air filter is clean.
Any ideas much appreciated.
1) Air
2) Fuel
3)Correction
A scanner with a VE (Volumetric Efficiency) function can narrow it down in a short test drive.
All PIDs should be evaluated in that there are so many possible culprits. If it only occurs cold, my very first look would be at the value read-out of the coolant temperature sensor and the ambient air temperature value.
get an inexpensive vacuum gauge and read idle vacuum, snap the throttle for a split second to over 2000 RPM and make sure vacuum drops to under 4 inches right quickly. Upon letting the throttle snap back to idle position, you should see over 20 inches of vacuum. This will check for exhaust restriction such as a clogged cat or muffler.
