Compatible parts for DNX-9990HD
ajent
I'm going to buy the unit once it's out, so for now i'm on crutchfield buying parts i'll need for the install.
Will the Ipod cable most likely work on this new model as well? Is there any chance at all I can get my XM antenna to work with this unit, or will I need to buy the XM adapter as well?
Finally, will the steering wheel control adapter work with the 4th gen RAM?
Thanks
quietpeen
2021 TRX
Hellcat
i believe the pac makes a steering wheel adapter that works. I read that you can take the plug apart for the siruis antenna and get it to work in an aftermarket sirius adapter. The stock ipod cable works through mygig i believe so i doubt it will work with aftermarket equipment.
MADDOG
Out Exploring Arizona
You may need the PacAudio iPod integration kit vs. re-using the stock one.
You def need the PacAudio adapter for the steering wheel controls.
Not sure about the xm antenna.
Are you doing an amp as well? If so, there's one more harness to get.
ajent
ajent
Yeah I planned on getting an amp, the fox box & 2 subs
Sorry, I should've been more specific. I meant would the kenwood accessories that are currently available on crutchfield be compatible with the new unit coming out. Their ipod cable & their steering wheel controls, etc.
tigger54
