Condenser Fan
Vikona
Ontario, Canada
Hello
I have 2010 Ram 1500 with the Hemi and the condenser fan is on high as soon as I put the A/C on. I replaced the condenser fan thinking it was is and it wasn't, I switched the two relays in the fuse box and it still runs on high so they are good. Any advice would be a great help at this point as I can't find any info on it.
Thank you
Hello
Thank you
It should be on with the A/C , turn the A/C off and see if it kicks out,if it does that's pretty normal operation for the electric fan.
V
Vikona
Ontario, Canada
It does go on and off with the A/C, but is it not a 2 speed fan cause its on high speed right from the get go?
Thanks for the reply
