06 Dodge
- Jan 4, 2022
- 1,917
- 1,811
- Location
- Forest Grove, Oregon
- 2022
- 6.7L CTD
Been trying city driving experiment, where I engage T/H & E brake, then select to only use 1-4 gears and have seen an increase so far of 1/2 mpg in city mpg numbers on EVIC... I also need no difference in mpg numbers when using T/H on the Hwy at 70 MPHI've found more of an impact on city mileage with no real impact on highway mileage. The city mileage is impacted because of it staying in lower gears longer. I don't think it is more than 0.5mpg difference though. It also depends on the speed limits. If you speed limits get you to the same gear it probably doesn't impact it as much as it would if TH holds you in a lower gear at the speed you need to run.
On the highway you are in high gear most of the time anyway so I don't see much impact. On the Highway I run 70 with 4.10 gears so I'm always in highest gear. If you run slower or with taller gears you may see a highway MPG impact do to it running a lower gear.
