Ramboy98
I have 98 Ram 1500 5.2 V8 I just replaced water pump.....Before replacing water pump the coolant gauge would rise a bit then lower itself. Now it still does it. I have really good heat..systems seems to be building good pressure. Truck does not over heat. I tried burping the system and still no luck as to why the gauge moves so frequently.
radiator cap also does not get as hot as it should even after long drives. I'm worried that the engine constantly going above 210 in temp will cause engine damage.
