Hardracer
- Jun 11, 2017
- 360
- 311
- 2010 1500 laramie 4x4 crew cab
- Hemi 5.7
I'm having 2 issues I'm needing help understanding more..
1.changing spark plugs soon on a 2010..I read somewhere that you can swap to iridium plugs without changing coils...I ve read 1 says u have to change,another says you dont....cannot find either posts to save my life...
Did just read goto rock auto their charts are good so I did then find like 5 plugs for it.
So what's the consensus here on the subject?
2.i changed the water pump last week for the 2nd time.
1st pump mopar original lasted 7yrs,2nd pump napa lasted 5 yrs..got lifetime warr.for that and they honored that no problem...both those pumps seemed to be a common bearing seal failure I'm guesing(pulley wobbled leaked everywhere)
--Question 1,...is why?can/is the tensioner be to tight?lucky coincidence?
That being said...i replaced quite a bit of coolant with the called for hoat I believe.little over 2 gallons...now I've noticed my temp seems to rise quickly when started(way faster than ever before) to the 203-04 mark as it should...I kept the factory t-stat as it still looked brand new...its functioning as it should,...the temp does drop down to the area of about 190(never did that before)until it rises back again then always holds steady at 203...
--Question 2,....do you guys feel this is normal the way the temps are acting at the beginning?..never seen this before in all the 75k miles or so I've had it...145k area now.
Is the new coolant mainly the reason?..
Just my thoughts as Iike to know what's going on and why.
Thanks all for your thoughts on both matters.
