Philip Gao
- Jan 27, 2021
- 32
- 12
- Location
- Canada
- 2012 Ram 1500
- Hemi 5.7
Here to ask professional guys to find the vibration source:
2012 Ram 1500 4x4 HEMI 5.7
Problem phenomenon:
a vibration come with the running, obviously vibration when the Ram speed between 105~115KM/hour, more than 120km/hour is better
Recently 2 years repair:
1) a new front drive shaft ( but it rarely use in 4x4 mode)
2) two new U-Joint in rear drive shaft, replace the fluid of rear differential, personally diy it, here require disassemble rear differential, really difficult for the big nut
3) two rear pack brake assembly replacement
4) left rear ABS parts (speed ring & sensor)
right now the vibration can be feel in steering wheel and all truck, not serious, do not sure some wheel bearing need replace
Could record the truck running voice, record in different speed, according the noise frequency, to identify some bearing or parts need special inspection?
Thank you and Be in Peace!
Problem phenomenon:
