Cummins Questions
Cutleys
What is the best year for the cummins motor as far as hp torque and pulling ability goes any other info would be appreciated as well. And is the cummins motor more reliable than the power stroke or duramax.
justin13703
MD
As far as third gens or across the board? Obviously the newer trucks will have more power and towing capacity as technology increases but also become more computerized/electronically controlled. If I were to buy a 3rd gen Cummins it would be an 06 or 07 5.9, that way you don't have to worry about the emissions equipment that came on the 6.7 engines.
C
Cutleys
Was 07 a split year cuz I know a guy who has a 6 7 in a 07 he has.
MADDOG
Out Exploring Arizona
I would agree with that. The 5.9L, without all the emissions crap, is easier and cheaper to mod so you can bump the HP and torque past the 6.7L diesel stock ratings pretty easily.
C
Cutleys
Awesome thanks guys what are your thoughts on cummins conversions I have a 06 2500 with a hemi would it be cheaper to convert that or just buy one.
MADDOG
I'd just buy one. There is a LOT of changing to do to make a Hemi to Cummins conversion work. It may prove to be more expensive than just swapping trucks.
justin13703
MD
Yes 07 was a split year, you could get a 5.9 in the earlier 07s and the later ones switched to the 6.7.
But yes just buy one. A swap will cost more time and money than its worth and probably will never end up being 100% anyway.
Ftank
