Datalogging for the Trinity
fat frank
About ready to gas it up with the 93 and load the tune for it. Do I understand this right? Will it start recording info if I leave it connected while I'm driving.
If so, should I go ahead and hook it up while I'm still running the stock tune and just let it record some data for you?
Again, if I just plug it into my truck without loading a tune, will it record data with the stock tune?
Thanks in advance.
hemifever
Preferred Vendor
Apex, NC
I only need the datalog after my tune is in there. Crank it up and then select the pids that I put in email. Then drive it for the 3 or so minutes and then stop the logging. It'll save it to the tuner and you can pull it up when you get home while using the data viewer application from Diablo's website.
F
fat frank
Thanks for the info. Looking forward to getting your tune installed.
Later
