BlownGP
- Feb 10, 2013
- 6,082
- 1,573
- Location
- Houston/Baton Rouge
- 2018 RAM Harvest New Holland Blue
- 5.7
Many people have and won. There are cases posted all over the net that show dealers denying warranty for this and that. After investigations into cause of failure, the Magnuson-Moss Warranty Act always came into play and if it was proven the modification (or tune) was proven not to be the cause, the manufacturer was forced to do the warranty work.
Is it a law? No. It is a precedence that guides legalities regarding accountability for manufacturers.
I had a 2001 Silverado in the Summer of 2001 - bought it with 21 miles on it. At 600 miles, it caught fire. Total loss. The fire started in the instrument cluster while driving at night with the lights on. The ONLY mod I did was a set of lighter wheels. Repair/replacement thru GM was denied because of the modification. After multiple investigations, it was determined the cause was a 22ga wire with a 20amp fuse where a 16ga wire and a 7.5 or 10amp fuse should have been used. They were forced, under the Magnuson-Moss Warranty Act to cover damages, even though they were trying to get the investigators to believe that wheels that were 14lbs lighter than factory created a reduced resistance in the electrical system that governed power to the cluster lights...
Just depends on the circumstances and the dealer, but don't except anything because of the MMW.
Fact is, dealers arent playing around with people tuning there cars anymore. Look at what's happening to the C7 Z06, granted it's not a truck but GM flat out has said if you want the most out of the Z06. You will need to consult a aftermarket tuner but if you do your warranty is voided.
