debadge
trentehrlish
5.9 magnum
What do I use to get the glue off of truck after I debadge. I don't want it to take the clear coat off. Thanks
T
trentehrlish
5.9 magnum
What do I use to get the glue off of truck after debadging it. I don't want it to remove the clear coat on truck. Thanks
Marksman
1999 Ram 2500 4x4 SLT
V10
I've always used rubbing alcohol on adhesive and it's worked pretty well. Wont hurt the paint either.
Today I re-badged the truck i just bought because someone removed them...
blkbaretta
TN
Goo Gone - works great - just clean with a little soap and water after - may not be needed, but why not?
dudeman2009
2001 1500 Sport with enough electrical modifications to make my brain hurt
Magnum 360
I've used goo gone which works pretty well. I've also used a rubber type wheel that goes in a drill to remove decals and pinstripes from vehicles when they become ratty, it also works great on tree sap, no damage to the clear coat either. I picked one up at Menards, but its something like this
https://www.amazon.com/Follex-ERW-6-Decal-Eraser-Wheel/dp/B00BMU9CEM
T
trentehrlish
5.9 magnum
And just use a rag to wipe the glue away? It's thick and hard.
T
trentehrlish
5.9 magnum
What do I use to get it off with the alcohol. Its super hard to get off.
Desert Dude
Goo-gone works good.
Sent from my SM-N900T using Tapatalk
quietpeen
2021 TRX
Hellcat
Eraser wheel is the no sore finger way
nateinva
Central Virginia
2011 1500 Laramie CC
5.7L
I did mine last weekend. Took about 1.5 hours with some stubborn adhesive.
Initial removal with fishing line. Peeled off 75% of it by hand...the thick part. Used an eraser wheel for remaining 25%.
Wiped everything off with goo gone, quick soapy wash and wax.
The truck is metallic black and I have some very slight ghosting on the doors where the 1500 was. I'll get some polish over the weekend and go over it again. Love the clean look now.
Marksman
V10
I generally peel off what I can and pour some rubbing alcohol on it which usually softens it up a bunch. I just use a rag to rub off the excess.
The eraser wheel method might be the easiest though. I haven't had the chance to use one yet.
quietpeen
2021 TRX
Hellcat
If you don't have an eraser wheel I would use something like goo gone and even a heat gun to Soften it up.
vgoodson91
Use a hair dryer to heat the remaining glue up and roll it off with your fingers. Then use goo-gone or goof-off and a microfiber cloth to clean the residue off.
Jems007
