From what im told before you tear it all apart just listen real carefully when you turn the knob to change from vent to defrost you should hear a small motor turn. if you do then you will need to change the door inside the hvac (PITA). If you don't here a noise then its probably the motor on the outside of hvac (less PITA). Am I correct everyone?
I don't hear the motor so whats everyones opinion on that. I see posts for replacing the mode doors and getting the parts at heatertreater.net if its the door I that needs replacing but not many posts about if you don't hear motor. Could it be the Motor or could it be a fuse or what about the whole temp control dash? There are no vacume lines running our doors correct? What does everyone suggest in my case and if its the same issue for David
