Mattrich67
- Feb 11, 2017
- 12
- 1
- Location
- Las Vegas NV
- 2003
- 5.9l S.O. 250 hp
I have a 03 Cummins 2500 4x4 I have built Trans edge cts2 w hot unlock air intake 4in exhaust and now a fast 150 titanium
So my problem has been for months. If I am sitting at a stop light and floor it WOT. The truck does not take off. It surges and hesitates. Like its running out of fuel. Rail pressure goes up around 14k-16k psi and sits right there. blows small cloud of black smoke and turbo spools up to around 20 psi. If you let the throttle up and get right back into it. It takes off like it should. rail goes to 23k 35psi of boost
Now if you take of with it even going 2 mph it will take of fast, smooth, and strong.
Freeway drives and has no problem
What I have done so far is
First clean all grounds
new batteries
Clean and check all connectors to sensors
Replaced FCA
Replaced Map senor by air filter
Replaced boost sensor
Didn't help or change anything
Took it to shop
Shop checked return flow of injectors and and injector cut out test replaced number 3 injector returning to much fuel
Still the same but starts up faster
Next shop said in tank lift pump not enough fuel flow rail suckling dry
So I put a fast 150 titanium on it. Still no difference
The next shop says possible injectors but they can't guarantee it because all the injectors read within spec.
new batteries
Replaced FCA
Took it to shop
