Difference between "Normal" and "Tow and Haul"
miran
Could someone please explain to me what changes on the truck when the "Tow and Haul" mode is turned on. I can feel no difference when towing a trailer and turning "Tow and Haul" option on or off.
Thank you!¨
Miran
M
miran
Hmm .. thanks!
But as mentioned: i've played with that T&H switch while towing more than 2000 kilograms trailer - no change in gears, no change in revs. Nothing. Does it maybe affect traction control or something else? Or should I press that switch before driving off?
Mine is 8 speed gearbox.
Miran
ExpressRules
Southern New Jersey
2014 Express Crew Cab & 2019 Big Horn Crew Cab
It locks out your top gear so your rev's stay in a better range for towing a load.
Grown in Tx.
Pearland, Tx.
It takes away the o/d and increases rpm like mentioned before. I think it might change some shift points in the trany as well. If you don't notice a change you might have a bad button or something, because you should definitely feel/hear a change.
M
miran
I did some "test" today: driving up very, very steep hill and there is really some difference: with T&H disabled - it shifted at 2500 rpm while with T&H enabled it shifted at 3000 rpm (I guess it was from second to third).
Any difference in traction control or similar?
Miran
Andy578
Ontario, Canada
2014 Outdoorsman
with the 8 speed it really just runs higher rpm, spreads the gears out more and will down shift faster to give more engine braking. it will still use all 8 gears and MDS will still activate if the conditions are right
skHemi64
To note on the link provided above...
"Use of ERS (or TOW/HAUL mode) also enables an
additional underdrive gear which is not normally used
during through-gear accelerations. This additional gear
can improve vehicle performance and cooling capability
when towing a trailer on certain grades. In ERS mode,
gears 1 though 3 are underdrive gears, and ERS 4 is direct
drive. ERS 5 and 6 (Overdrive gears) are the same as the
normal fourth and fifth gears. NOTE: TOW/HAUL mode locks out Overdrive."
That said, I typically don't use Tow/Haul mode. Some stretches I can keep 6th just fine with my horse trailer. I will manually shift down to 5th for uphills, but also allow the rig to slow down some to avoid downshifting to 4th if possible. Although, might be a good idea to use Tow/Haul if you are in under-55 mph stop and go traffic, just to keep the rig moving smoothly.
clh1220
st Louis
He doesn't have your transmission. Totally different.
Valhakar
Cummins 6.7L/Aisin 6 speed
I can tell you from my butt-dyno testing that the Aisin tow/haul is EPIC. Without a load I can accelerate to 50 mph, let off the gas, and it downshift aggressively and uses engine brake. Enough to send you into your belts. Turn T/H off and it just coasts gently down the road.
SouthernBoy
Central Texas
I LOVE the Tow/Haul mode on my new 6.4 - it shifts exactly where I want it to when towing and doesnt downshift too early either. My older 2009 6.7 sucked with Tow/Haul turned on, the downshifts alone would throw you into the dashboard.
reindeerman
Knoxville, TN
2011 & 2002
I have a 2011 4.7. Love the tow mode. The downshifts are spot on and aggressive for engine braking. Since I tow 95% of the time it is great feature. My 3rd generation doesn't do this.
JustinRam1500
