Our brakes are pretty big up front so some wheels might barely clear them. I know with my KMC XD Battalion in 18" they barely clear them and since the wheel weights are mounted on the inside of the barrel, they actually rub on my caliper and make a noise. I had to grind the weights down after the fact.
factory tires & wheels
Does anyone know the weight differences? I thought I could only tolerate the 18" as I think the 20's look weird. Are there any advantages to the 20s other than the way they look?
Some wheels have a higher load rating than others. There is not a form for wheels and tires on the 2015 Ram bodybuilder, but you can use the 2014 Ram bodybuilder spec sheet in the link below since almost all 2015 wheels are carryovers from 2014.
http://www.rambodybuilder.com/2014/docs/intro/twlnwv.pdf
Thanks!
Although I have no idea about which code is which wheel, it looks like they are close in weight.
