Disconnected hose
Kenny Bobb
Orlando
2014 Ram 1500 5.7. Went under the truck to do an oil change and found what seems to be a vacuum hose hanging loose, I can’t find where it should be connected. It’s on the driver side under the brake booster rear of the wheel well. See photo. Looking for ideas where it connects.
It's the breather vent for your 8 speed transmission,there should be a bracket/clip to hold it on the backside of the engine so it lays more on top of the engine then down by the manifold. If the clip is buggered a zip tie should hold it in place so it isn't melting onto the manifold.I'm guessing either the engine or transmission have been worked on,and the clip was never clipped back in place.
