DIY Intermittent Wiper Multi Wipe per cycle
RamRod37
2014 Ram 2500 HD 5.7 Hemi
Georgetown TN
Intermittent Wiper Multiple wipe Fix
you need to remove wiper arms and the wiper cowl there is a small screw in each end of the cowl and some plastic push in clips across front side of the cowl once cowl is removed theres three 10mm bolts in wiper motor one closest to firewall two in upper backside of wiper motor remove the three bolts and the one 12mm nut holding the wiper linkage arm to motor remove it as well now unplug the electrical connector from motor and remove motor then the black plastic cover that's on motor release the 5 tabs that holds cover then remove the cover you will see two spring contacts some contacts on cover remove all the white grease that's on both cover and spring contacts save some of the clean grease on a Q tip to put back on now with some very fine sand papper 300 or 600 grit lightly sand down the contacts on cover then reapply some of the grease back on cover light coat and a little dab on each spring contact then reinstall cover
NOTE Make Sure When Doing This Don't Let The Gear Come Out of the housing
Now Reinsatll Motor plug Electrical connector Back Up And Install The 3 10mm Bolts Back On motor not the arm bolt just yet after motor has been remounted turn on wipers to the highest Intermittent setting let the motor Cycle A Few Times it should be working correctly now. Now you can turn them off with wiper switch first before turn Ignition Switch off this makes sure that wipers will be in the parked position now you can Reinstall the wiper Linkage arm the arm should point straight horizontal to driver side before tightening down the nut now you can Reinstall The Cowl And Wiper Arms it may take a couple of times setting wiper arm back on wiper arm studs Position Wiper Arms so they park about 1 Inch From Bottom of windshield
This took me like Between 30 to 45 min to do and they work right now
Sorry No Pics Was Not thinking About that at the time sorry
CorDog009
East Texas
I think those are the longest run-on sentences I've ever seen. :) So what exactly does the mod do?
RamRod37
RamRod37
Georgetown TN
Comments like that you can keep to yourself Some people Had fun with other things during school like parties and sex and didn't want to even be in school so we didn't pay attention like we should have This Is A Info Forum If It Don't Have To Do With the forum topic keep your mouth shut
CorDog009
East Texas
I guess you didn't catch the sarcasm with the smiley face...
I guess I was missing out on all the parties and sex when I learned that stuff in Elementary school.
P.S., you never said what the mod actually did, which was the question I asked in my first post.
RamRod37
RamRod37
Georgetown TN
I edited the post and added Description forgot to when I made the Thread Intermittent Wiper Multiple wipe fix
Spectre
Georgia
I've got this problem. Finally a fix. Thank You for the post. It is like a haunted system. It invariably selects how it thinks it should wipe instead of how I set the control. Plus mine will wipe as I'm cruising down the road and it's a beautiful sunny day. I just tell people with me I mentally controlled it... Bleh
bbc454500
Northern Canada
Cummins
hello there I just purchased a used 2007 3500 cummings and this just started doing the same as you described so I will testing your explanation this weekend ill let you know
Smokeybear01
US-NW Coast
Cummins 5.9
I have the same haunted wipers on my 2005. Just as soon as the sun comes out I will be giving your fix a try. I already did the relay switch which was no help. I'm just hoping I don't have to replace the control arm, I like your 'inexpensive' fix a whole lot better. Thanks
Tray Burge
On the porch
Yeah, literacy is over rated. Bawhahahahaha
Hell, it's a shame, but my grown ass adult kids can't even write in cursive! I was floored when they told me it wasn't taught anymore, no wonder we have so many illiterate Socialist running around? (OP, I wasn't in any way implying you are one either)
Juhax
Finland
6.7 diesel
It is easiest to change a new wiper motor! It was cheap. Even here in Finland!;-)
