vasi
I have a 2019 RAM 1500 limited with a 5.7 HEMI.
It has done quite well towing a trailer with a weight of about 4000 pounds.
I exchanged that trailer for a toy hauler that has a dry weight of 7000 pounds. I will carry my motorcycle which has a weight of 594 pounds.
Thus, the operating weight of the toy hauler could end up being 8500 to 9000 pounds. While this is below the towing capacity of the 1500 it is near the limit.
When towing the lighter trailer the truck was stable and steady. With the new trailer it seems to have more movement. It does not sway, because I have sway bars, however, there movement in pitch.
As we know, the 2500 is an expensive truck, I don’t want to put out the expense if I don’t need to.
1. Am I putting my truck, and myself, in a dangerous situation by towing near the maximum limit?
2. What do you think is causing the pitch movement? Could this be related to the hitch?
3. The 2500 comes standard with a 6.2 hemi, as I recall. Although this engine would result in less towing capacity, it would be adequate for my purposes. What is your opinion on the HEMI verses the diesel?
