Disclaimer: Links on this page pointing
to Amazon, eBay and other sites may include affiliate code. If you click them and
make a purchase, we may earn a small commission.
Ok looked it up. Exactly what i need. Can you please help me find the exact products i need? Was looking at the kicker wislok... need to know what guage power wire, fuse etc. This will be for 1200w subs.
You will need something that provides remote turn on for your amp. Unless you tap into a fuse. 4 ga wire is probably fine. 0 ga no doubt. What amp are you running? that will help to know what you need.
Ok so i was just doing a little research and i came across fox accoustics box and then researched subs and saw the alpine type R... think im going in that direction. So looks like im going to need an amp 2000+
I think the new type r ia rated 750 to 1500 watts. Might be hard finding a single amp to do that. Two 1000 watt amps would be easier to acquire imo. You'd likely need 2 sets of 0 gauge or single 00.
The fox box is amazing. If you're planning on that much power to your subs, you better do the rest of your system or you'll never make it sound very good. It's not going to blend well at all
