Door boot removal?
EWC88
Southern NJ
I think my passenger side door has some wires that are torn because the control for putting the window up on that side works when it wants to, master controls work all the time. Also the rear passenger door isn't working 100% all the time as well. So I was wondering if the boot removal is hard and how to go about doing it? I seen some people that just cut it but I don't want to do that.
hotkarl
4.7 Semi-Hemi
Nooo! Don't cut it! Ha ha!
Peel back the rubber boot from the plastic connector that secures it to the sheet metal. Should have push in tabs to release it. On the door side just pull the rubber out of the hole (no pun intended).
E
EWC88
Southern NJ
Sweet I'll have to do this next time I'm off.
xb1230
Hobby Mechanic
South Shore of Montreal, QC, Canada
You can use some wd40 to ease the pull-out re-install. Good idea not to cut the boot.
Also you can remove the door panel and pillar cover to help access the harness and help the removal of the boot.
PdPuNOme
Jersey
I use bulb grease or dielectric grease for pulling boot back over plus it helps in all the bending over time, so it does not dry out and crack as easily. Double up on the shrink tube as well that will help.
kawisser
Fishers, IN
4.7 V8
I know this is an old post but I need some help. I'm trying to remove the boot, but I just can't figure it out. Does the rubber piece just slide off and away from the metal? I'm afraid to pry it off too hard thinking I may break something.
Should I pull the left side away from the metal in the 2nd attached pictures?
tumtum512
5.9l Cummins
yes cabin side, what you have a picture of, if you look closely at that rubber cover going to the cabin it has 4 push tabs in each corner... other people have no problem getting there's off, I could not get mine off doing my stereo install and had to rig around the issue! my two cents...
