Just realized today that my sun visor mirror on the driver side isn't illuminating.
I decided to check and replace the bulbs with something else (a small led board) and popped out the bulbs (bad idea as they were tiny and soldered directly to + and -) by cracking them and having to remove shards of glass in the process.
I then realized that there was no power getting to the driver visor mirror and got out the test light. The ground seems to be working fine, but positive doesn't work for some reason.
The passenger side works fine, and if I have to I will just tap into that side and call it a day. The map, and rear top center mount work fine.
I looked for a fuse and found nothing under the hood. Should I be looking elsewhere? -- My next step was to remove the visor and check the connections to rule out the board being bad.
Is there something I'm missing or should I look elsewhere to troubleshoot it?
Any input is greatly appreciated.
Tia.
Tia.
