DuraTrac...?
NavyDave
Millington, TN
'14 1500 5.7 Laramie... I'm still a bit of an all around noob so bare with me. My truck is stock and I'm shopping for tires. Right now I'm thinking about the DuraTrac's in 275 60R20, will these fit? Am I making a bone head purchase? I see a ton of posts about lifting or leveling to prevent rubbing and I'd like to be sure before handing over the cash to order them.
nateinva
Central Virginia
2011 1500 Laramie CC
5.7L
You shouldn't have any problems as that is the stock size. It's is spec'd at the same 33" diameter.
Where you'd start running into needing other upgrades would be going taller and/or wider.
A 2756520 Duratrac will be 34" diameter for example and cause some rubbing if you don't level the front.
My tires are 34.3" dia. and I have a 2.5" front level. The driver's side rubs the plastic slightly at full lock. It has a date with my Dremel soon as I see the rub mark now.
nateinva
Central Virginia
5.7L
It's a great looking tire and I've run them myself...very happy with them.
I'm running kanati trail hogs now...they are cheaper and look very similar.
NavyDave
NavyDave
Millington, TN
Thanks for the info and the relief, I'll check out the Kanati's too
bcbouy
pitt meadows/100 mile house
2021 power wagon
hemi
the only bone head move will be buying dura tracs.a great looking tire? what kind of ..never mind.
iam_canadian22
northern ontario
Duratracs ftw! No issues with the size, same size as stock 20's. 285/60's also fit no issue, and 275/65 fit no issues on my new outdoorsman
nateinva
Central Virginia
5.7L
How is the road noise with the Goodyear Duratracs?
Not bad at all. The Duratracs stayed pretty quiet with wear. Running Kanati Trail Hogs now and they are significantly louder with wear.
Orca
