chris52010trx4
my ebrake cable is sagging more than normal.. and has for a while.. after reading up on a few forums im sure that somethings seized when i apply the the parking brake pedal slack is taken out of the cable but it seems like where the spring hook meets the rear axle nothing is happening... it seems positioned in the middle of the slot if that makes sense... is it the normal position? i doubt it but any input would help... i dont think the brake is dragging because when i put it in reverse and let it idle back theres no resistance but still its hard to tell with the power of the motor or if the pads are worn out i guess... is there a way i can adjust the cable without pulling the wheel and rotor? i sprayed some wd 40 on the slot where the spring is but it hasnt freed it up any.sorry for the rant just would rather something worse not happen.
