Eibach Pro Lift Kit
crazykid1994
Did you find they stiffened up the front end abit more? I did the eibach set up and love it but have been thinking of doing the Maxx suspension ones or these
Sent from my SM-G965W using Tapatalk
They did stiffen it but my stock ones were completely shot so... personally you’re probably better off with the suspensionmaxx ones since they’re a direct fit.
chris52010trx4
ontario
The suspension maxx are abit more expensive to get here in Canada so ill probably do the others
crazykid1994
Just got my sway bar links in. All I can say is holy **** these things are beefy compared to stock..
When I did mine I used a nylock nut on the bottom. Hopefully you can find a 12mm or 7/16” bolts and nuts. They were in short supply at my local hardware store.
chris52010trx4
ontario
I thought about a nylock after I left tsc... found the 7/16s bolts and just bought some washers and lock washers should be okay will double check after a cruise or 2... the hardest part was grinding the weld off the clevis without mucking the rest up all good pretty simple install1e3f7c3d7f138542b30c4dc9d07d3da3.jpga627151625d83d390eca717a18dd1138.jpg
