- Feb 7, 2020
- 832
- 1,452
- Location
- Greater Cincinnati area
- 2014
- 5.7 Hemi
In short:
Question is, if I am expecting battery voltage, say 12.6V, to a headlight, but I'm only reading about 6.4V, what is going on?
Possible short, or bad ground?
How best to narrow down the search for the issue?
This is my son's golf cart, and 1st it started blowing the fuse on the lighting circuit. I got that working (wiring all looked ok, no obvious broken insulation or cracks etc but did have extraneous wires running nowhere so cleaned it all up, replaced the key switch which was acting goofy) and no problems for a month or so.
Then one day it wouldn't start and lights didn't work. Replaced a couple things (ignitor and voltage regulator) because they looked like they'd gotten hot at some point, and found more weird wiring and cleaned that up. Lights worked, started and ran fine for a week.
Now it won't start. It won't try to turn over, key on, press the accelerator, nothing happens. Lights worked then didn't. There's battery voltage to the key switch, to the accelerator microswitch, to the solenoid. Solenoid is ok.
This is a simple machine and simple wiring, but it is a 2006. I swear I've been through literally every wire and checked grounds but obviously I've missed something.
Any suggestions as to how to narrow this down to find the problem and fix it once and for all? I'm about to just rewire the whole damn cart.
