Error code.
Mojo75
5.9 Magnum
Finally got around to the check engine light and I got a gas cap error and 1491 fan relay. My blower fan only comes on in high but I notice my truck randomly overheats too. Which fan woukd you guess this is a code for?
RamRod37
2014 Ram 2500 HD 5.7 Hemi
Georgetown TN
That Code shows Rad Fan Control Relay Circuit either the relay is bad or you may have a fan going out
I did mot know ram had a electric rad fan on the 3rd gen mine don't
HemiSLT
Hemi 5.7, Ecodiesel
That code is for the A/C condenser fan under the hood and not the blower motor under the dash. I'm sure your fuse is blown which would indicate that your fan is bad and needs replacement. This should not cause your truck to overheat though. Hope this helps.
RamRod37
Georgetown TN
that code info was pull directly from obd site and that's what it said rad fan It didn't say condenser fan
HemiSLT
Hemi 5.7, Ecodiesel
Sorry RamRod but these trucks have a mechanical fan for the radiator and therefore can not throw a code due to no electrical components. They do have an electrical condenser fan that will throw this code since it is powered through a fan relay and fuse.
RamRod37
Georgetown TN
oh I know that that's just the code 1491 shows to be is what im saying
HemiSLT
Hemi 5.7, Ecodiesel
Yeah. I hate how misleading those sites can sometimes be. I know that Mojo appreciates all of our help! Take care.
Mojo75
Mojo75
5.9 Magnum
Yup blown fuse. I do appreciate all the help!
Mojo75
Mojo75
5.9 Magnum
Since this is just a work truck and AC is the least of my worries is there a way to just bypass it if it's bad? I can't get the truck inspected with the code
Mojo75
Mojo75
5.9 Magnum
Sure enough a new fuse and a gas cap and no error code. Now I'm closer to inspection lol
HemiSLT
Hemi 5.7, Ecodiesel
As long as you don't use the A/C, you will not reset the code. If you do use the A/C then the fuse will blow again and the code will come back. What code did you fix with the gas cap?
Izzyb47
Northern NJ
Mopar 4.7l
If the cooling system is overworked and the compressor is building too much pressure it could cause slight overheating.
thoffmann517
