EVIC re-set
donno21
Las Vegas Nv
Cummins Diesel
EVIC will not re-set after tpms was corrected Will not respond to selections by using owners manual. 2011 RAM 2500, 4wd, Cummins. HELP
R.L.K.
Bristol , Tn.
Try this .
Disconnect the + & - terminals from the Battery , next touch them together for about 10 seconds . This does a soft reset of multiple modules throughout the truck .
Leave both terminals disconnected for at least 30 minutes, over night if possible.
Hope this helps !
Joji91
Just drive it for a while. Mine took a day to read them again.
TonyMM
2016 RAM 1500 CC 6"4 4X4
I assume both batteries must be disconnected?
Both batteries? I for sure know where I have one near the engine. But where is the second batterie?
Joji91
I think he means both terminals of the battery.
R.L.K.
Bristol , Tn.
Both terminals on your Battery. To my knowledge, you have only one battery .
Hope this helps.
R.L.K.
Bristol , Tn.
I'm not familiar with the 2500 diesel trucks , but if you have two batteries then I'd assume you have a Main battery that's connected to the PDC (Power Distribution Center ) aka fuse box .
This would be the battery to disconnect and touch the terminals together for a soft module reset .
If both batteries are connected to the PDC then yes perform this procedure on both batteries. Make sure all batteries terminals are disconnected prior to touching any terminals together .
Hope this helps , sorry for any confusion.
D
donno21
Las Vegas Nv
Cummins Diesel
Yes, the Diesel has 2 batteries. Thanks, I'll try the disconnect trick.
Joji91
Let us know how it goes.
D
donno21
Las Vegas Nv
Cummins Diesel
Sorry it took so long to reply, been busy. I disconnected batteries and touched the cables together as was suggested. I left them disconnected over night. I can scroll to "system setup" and that's it. Any more ideas? Thanks.
jwheeler
Washington
There is no reset procedure for low tire pressure. It may take a couple miles of driving but if it still says the tires are low, they are low or there is a bad sensor.
D
donno21
Las Vegas Nv
Cummins Diesel
Tried the cable disconnect thing, even left them unhooked over night. Still wont come out of "select" mode. HELP!!!
D
donno21
Las Vegas Nv
Cummins Diesel
I corrected the tire pressure and drove the truck, tire pressure light(s) went out The problem is the EVIC wont reset. (miles vs KM /mileage / miles to empty etc) I get as far as SELECT and that's it. Any thoughts?
D
donno21
Las Vegas Nv
Cummins Diesel
The problem IS NOT with the tpms, it's fine. It's the EVIC will not come out of "select".
R.L.K.
Bristol , Tn.
Hmm , I wonder if there's a module for the evic ?
It may be part of the instrument cluster not sure .
stimpy433
IOWA
Could be your steering wheel buttons are messed up, I know it's happened to others.... might be why you can't change your EVIC screen???
