Ttrue
I Bought my 08 Ram 1500 5.7L Hemi a year ago. Was in rough shape mechanical I've replaced the water pump, Thermostat, radiator(guy had jb weld around everything) both top and bottom idler pulley, tensioner pulley assembly, Both front end wheel hubs, sway bar and links. Had a AEM brute force cold air intake installed half ass. I remounted it the correct way pretty much everything that has been neglected and still have more left to do. I bought this as a project truck to teach my 3 sons as well as myself how to properly care for and maintain a vehicle. Plus to have a little fun. Last week the muffler literally exploded. Sounded like a giant can of biscuits popping then just an insane metal rattling. I had a flowmaster super 40 so i just went ahead and put it in. Truck had a Y pipe from the muffler exit to duel exhaust. Cat looks to be the original. While I was at it I decided to check the whole system and noticed a slight tick I tracked to a bolt for the exhaust manifold. Spraying some soapy water I noticed passenger side had a pretty good leak, driver as well but nearly as bad. So I'm going to just replace gaskets,bolts, manifold, and heat shield if needed. getting to the meat of my question is it worth it to buy a performance header? If so what would you recommend?
