Davidius
Hello, while installing and programming my factory remote start and trailer brake controller with alfaobd, I poked around other settings and I noticed a setting for the rear windows potentially being one touch up/down, of course it didn't work. My truck is a 2013 1500 tradesman crew cab ram box, Is there a way to add factory right front door modules and window motors to the rear doors to make all windows one touch up/down? The additional wiring isn't a concern, my biggest question is will the body control module recognize two addition RF door control modules on the CAN IHS bus as rear door modules or would I need to find rear door modules and motors out of a newer pacifica or similar that has one touch windows? I've looked into the autoloc and DEI options as well but once I started thinking about using factory parts, I went down a rabbit hole and decided the CAN and BCM will be the biggest hurdle, any input? Thank you.
