Front coil spring spacer questions..
dram1999
My local part store sells 1 1/2" coil spacers, I was wondering if I were to put one on the top and one on the bottom of the front coils, would that lift the truck 3 inches
D
dram1999
What kind of problems is it going to cause?
dodge dude94
Millennial Boomer
East Texas
1998 Ram 1500
5.9 Magnum
Well...you don't ever put a spacer underneath a spring, for one. It lifts it out of the bucket and you get the high likelihood of it escaping at the most inopportune time.
D
dram1999
I found some coil spacer rings that have a cut in one side that fit inside the coils.
Thank y'all for the help
Merc225hp
NA
truck
gas
So you came here looking for advice about spring spacers used under the coil-spring, all said bad idea and yet you are going to do it.
As posted its a bad idea and should not be done, get a set of Hellbent 3" spacers.
Johnn123
Ontario
For your own safety please dont do what you are planning to do with those spacers..........
D
dram1999
I'm not putting the spacers on the top and the bottom. The spacer rings I got with the cut in them goes in the middle of the coil and winds up the coil.
Merc225hp
NA
truck
gas
I have an idea on what you are now going to use, these are not what you need or want to install in your 4wd truck. Get a set of proper Dodge Ram coil-spring spacers they are not that expensive and will work much better than any rubber insert that goes into the spring coils.
darkhorse84
walla walla
That or swap out your coils for some 3500 coils. That will lift you. But really bad idea on the spacers.imho
ADudeOnSkis
Truckee, CA
318/5.2 Magnum
Do what the man says. Do it.
More importantly, DON'T, do what you are talking about doing.
bassslayer25
East, Kansas
5.9 360 V8
The ones you want to use are a waste of money. I did it to an hold f150 and it didnt make any difference what so ever.
newrammer
5.9 v8 magnum
The 2nd type you were talking about...bad idea. I've seen those go wrong so many times.
96DodgeRam4x4
5.9 Magnum
First time ive ever seen anything so ridiculous. wow is all I can say. might as well stack six 1" blocks while youre at it.
