Front Differential cover
Poncho
Was just wondering if anyone has ever removed their front differential cover. I have a 2012 ram 1500 4x4 with the 5.7 and have noticed the there are bolts on the front diff.
crazykid1994
What is your purpose for that? Curious. To see what it looks like or for taking it apart? There are a few videos of them being disassembled
Zoe Saldana
california
6.4l
Have you ever changed the fluid?
P
Poncho
I have searched 1000 of videos about fro t different and never found one that showed or talked about fro t diff covers. It was always they have to be changed as a whole. As for the reason I have a grinding noise and I think it's internal
Jeepwalker
WI
2012 Reg Cab, 4x4
Have you tried removing your front driveshaft and rotating the pinion by hand?
Might have to remove the front wheels too. A lot of times a guy can 'feel' things by hand. Check the inner CV's. Rotate/inspect the driveshaft & U-joints. Might check the wheel bearings when it's off the ground, but before you've removed the wheels.
crazykid1994
Yup. Generally if the front diff goes bad it gets swapped as a whole because up until very recently nobody has made replacement gears. so the only option was a new front diff. Now there is 1 company who makes replacement gears. Can you share a video if the noise? Could be bearings or the gears depending on the noise.
18CrewDually
U.S.- New Jersey
Cummins 6.7 H.O.
Check the output shaft to CV shaft connection. Moisture can get in the splines and rust. It can eventually strip out the splines of the half shaft.
I found a youtube video of it.
P
Poncho
I've replaced cv axles, wheel bearing hubs, intermediate Shafts, nothing helps so that's why I believe it's internal
