Front drive noise
jwin1845
I've got a fluttering noise coming from the front ends when driving. Pretty sure it's the front drive shaft and it's caused by the 7" of lift. I got under there and played with the front shaft and it makes some noise in the middle area that has the rubber boot around it when I try and turn it back and forth by hand. Can't really tell if the u-joints are bad or not. Let me know your thoughts on this
Jerseystyle
Do you have any vibration coming from the shaft?
Should only have 1 u-joint and a CV joint on the front drive shaft.
grand1500
your lift came with Diff Drop brackets right?
