front lift springs??
usaf2006
Augusta, GA
Does anyone know if a company makes lift springs for an IFS 4wd 3rd gen (06-08) ram? Just looking to substitute coils instead of leveling spacer for a 4" lift (bilstiens and lift coils combo) if possible.
Thanks
usaf2006
usaf2006
Augusta, GA
Are the springs taller than stock? They're not bad priced but i thought they were basically the same idea as bilsteins.
brandonjansen
Abbotsford, BC, Canada
2012 Ram 3500 Laramie Limited
Rancho Quicklifts are essentially the same idea as Bilstein 5100's. They just come loaded (with the springs and hardware) rather than just a shock like the Bilsteins and aren't adjustable.
If you go with a longer coil spring you'll need longer shocks in the strut assembly as well. You aren't going to find that. If you want to eliminate the strut spacer altogether then you'll be looking at coilovers.
thoffmann517
