Moose71
Started experiencing a front end issue at high speeds like a mini death wobble someone told me the front track bar may be bad. I haven't crawled under there yet what am I looking for cause at first glance I can't find it..
You don't have a front track bar.The 4th Gen 1500's use a solidly mounted front diff with IFS (independent front suspension),you only have a track bar on a solid diff whether it's front or rear,IFS rear suspensions don't use a track bar either.When the diff itself is solidly mounted,it doesn't move up/down or side to side like a solid axle does,so there's no need for a track bar.As stated above check both inner and outer tie rods / ball joints / wheel bearings etc.Just got new tires,alignment,replaced both sway bar links...I don't think I was clear in my original post what I wasn't seeing under there is the actual front track bar..
