Front USB ports?
DanAR
Arkansas
I noticed that the USB ports above the console appear to be on even when the truck is shut off. First time I’ve run into that but I’ve been in Toyotas for some years. I don’t guess in all this programmable electronics wizardry there’s a way to program them over to being switched with the ignition to prevent accidental battery drain?
thanks
DanAR
DanAR
Arkansas
Maybe I should have looked a little first. Found this in an older thread.
SO... there's another hidden fuse box UNDER the dash and you have to pull the knee panel to get to it. That's where the toggle fuse it, so the power ports get she off with the motor.
DanAR
DanAR
Arkansas
Looks like the USBs are on a delay after the truck is shut off so no need to look into this further.
