Fuel conditioner.
RickP68
Edmonton Alberta Canada
I just bought a 2017 2500 with the 6.7 Cummins, fully deleted. Was just wondering if I should be using fuel conditioner, when the temperature drops. I do use it in my Peterbilt when the weather gets colder, but I’m unsure if it’s worth it, for the 6.7.
2003F350
6.7 CTD
If you're just looking to keep the fuel from gelling at those temps, then yeah, I'd say run it.
If you're looking for any other performance gains, on modern trucks most of the products out there are snake oil at best.
truck2569
Clay Center Kansas
I have found out that it lubricates the system and dissipates the water just like it does in your semi. It only takes about 2 ounces but saves in the long run. I have a 2013 Ram3500 with 587,000 on it and still running strong.
