Gas has air
Ray0729
United States
5.9 gasoline
I have a 1999 Dodge Ram1500 Sport 4x4 5.9. I went to put gas but when I took the cap off both air and fuel came out the filler tube . Has anyone else have this problem and what did you do to fix it ?
NCRaineman
NC
2019 1500 Classic
The vent tube coming out of your fuel tank is likely clogged. Bugs love to make nests in there. You can try running a piece of wire or coat hanger down it, see if you can break up anything that might be in there.
R
Ray0729
United States
5.9 gasoline
I blew air through all air lines and they are clean . I cleaned the evap leak detection filter , and charcoal filter and still have the problem
NCRaineman
NC
2019 1500 Classic
Is the fuel system on the 5.9 return style? You may have a leak somewhere and air is getting pumped into the fuel tank.
Dodge 1500 4X4
Rochester, NY
The fuel vapor isn't getting drawn into the charcoal canister to be burned by intake vacuum, you should not have vapors in the fuel tank, is there a purge valve in the system.
R
Ray0729
United States
5.9 gasoline
Yes 1999 With 5.9 return vacuum .
Yes it has ; Evap Purge Solenoid
; Evap Leak Detection Pump Filter
I Really Appreciate The Help I Am Receiving !
Ray Sanchez
