Gauge readings??
H3MI UP
Southeast ga
Just wondering what you guys are running numbers wise on your gauges. Like what is your coolant temp,trans temp and oil pressure and temperature. Just curious as I just bought a 16 big horn with 6" lift and tires and want to compare my reading to what you guys are running.
lukedukem
Victoria, Tx
i took this picture of mine to document my mileage.
coolant temp is 201, its hard to see.
My truck is a 2015 crew cab with 5.7 and 8 speed. level kit with factory size BFG KO2 AT.
15.2 mpg is from idling a lot. its usually better
hope it helps
Luke
H3MI UP
H3MI UP
Southeast ga
hope it helps
Luke
Thank you. Just wanted to see how mine compares. Seemed to run higher temps then I expected.
jschwanke84
There are pretty wide ranges for all of these temps that are considered "normal" so I would not worry unless you are getting a CEL or your oil temp gauge is significantly past the midway mark.
OasisNinjaBat
