Gear ratio
Alextapia
What gear ratio would you guys recommend??
Ricks Ram
That would all depend on what you need and what you use your vehicle for. Do you already have your truck or thinking about buying one?
charonblk07
Calgary, Ab
F1-A forged 349ci
Tire size, driving style, average driving speed, transmission type, tow or not? These must be known to make a recommendation.
Ratket
Arizona-
Answer the above two questions BE SPECIFIC- if u already have the truck is it a 8 speed or 6 speed?
GP4L
Chicagoland
His info says 2012 5.7L, so I'd think it's safe to assume 6 speed, since the 8 wasn't available till 2013.
Ratket
Arizona-
well damn then that's all the info we need- to give our opinions, leave it stock.
charonblk07
Calgary, Ab
F1-A forged 349ci
That would also assume it's a 1500, a 2500 runs a 66rfe which has different gear ratios.
Hemi450hp
Moe's Performance
Preferred Vendor
Conroe, TX
2014 Ram 1500
Alex, if you have a 2012 1500 with 3.55's, then I would go with 4.10's. I am a big fan of higher gear ratios, but with the extra cost and hassle of stepping up to a 4.56, I feel the 4.10 is the best way to go.
If you already have 3.92's, then I would go straight to a 4.56 as the jump from 3.92 to 4.10 wouldn't be worth the cost of parts and labor.
A
Alextapia
Well you see I have a 266 cam and bolt ons I'm just trying to get my acceleration back because it's absolutely terrible
Hemi450hp
Moe's Performance
Preferred Vendor
Conroe, TX
2014 Ram 1500
With that cam, you want no less than 4.10 gears with a 3200-3400 stall tq converter.
A
Alextapia
How much it it would be for gears and what not its 4x4
OasisNinjaBat
